LPG just died on 940
- Jerry Stam (GAST)
Anyhow, there is no such thing as an overfilled LPG tank. There should be a valve in the filling line which closes once the tank is filled for about 80%. The 20% left is intended for expansion of LPG. If this valve is stuck, you can fill it up further, but this has no adverse affect on any part of the LPG system. The only risc is the overpressure safety valve blowing off when the LPG in the tank expands when it heats up in the sun.
Did the high idling also occur during running on petrol? If so, it is probably not LPG related, but due to a malfunction in the CIS valve (Constant Idling Speed) or the (setting of the) switch located on the throttle shaft. Cleaning of the CIS valve and throttle housing might also help.
You're in luck; there is plenty of knowledge about LPG systems in the Netherlands available!
Well, succes and i hope someone here can give you a good tip!
Greetings, Rudiger
From the description i think it is likely to be a Vialle AMS system, as Volvo used this system as the " Volvo" LPG system off the factory (or dealer). Later did Volvo use Vialle LPi but i think that was from '95 or so. LPi uses 4 additional in the engine bay, you have 3 which supports the guess that it would be AMS. AMS has no pump in the tank. AMS has an evaporator in the engine bay, I'm not so familiar with AMS but i understood that there is an idle speed controller in or near this evaporater with a stepper motor. Maybe cleaning/testing that might be a solution. Another thing to check is the relay that stops the petrol injectors to inject fuel when the engine is running on LPG. Too much fuel, both LPG and petrol, will stop the engine from running. This can happen smoothly, it can feel if you released the gas pedal and the car keeps rolling from its previous speed and weight but no reaction when you press on the pedal. Maybe someone can suggest more good LPG specialists near The Hague? I'm not familiar there.
pvrakking schreef : I drive a 940 from '91 with a Vialle AMS system. Mine gave troubles last year with LPG. The vacum operated valve in the LPG hose (between the evaporator and airinlet) did not work proper anymore. After removal the issue was gone.
Thanks. I learn more about the system now, and also how is it called.
I really do not understand how the system works on my car. That vacuum operated valve in the lpg hose is disabled - disconnected and fixed in one position with a piece of wire, yet the car run perfectly: starting at any outside temperature or motor temperature, changing to LPG automatically and running well, with normal low idling rpm... maybe first minute after cold start was not really nice when it is cold outside, but after that I cannot imagine that a car could work better... until yesterday - and after I posted an advertisement for sale, Murphy's law in its best appearance
With me it is definitely that the evaporator does not get LPG, both valves in the engine compartment are not operated.
There is an excellent Volvo forum in Croatia www.vkh.hr where they advised me to check a relay that is hung on the inner side of the right wing of the car - for which the specialist told me yesterday when I pointed on that, that it has nothing to do with LPG, so I am going to check that further today
Thanks I understand better how that system works now, that stepper motor is probably the thing on the evaporator with 4 wires, but the problem with me is that there is no LPG coming inside the evaporator.henk 940LPT schreef :
rudiger schreef : Hi Dusan, thats al long time ago! sorry i cant help you with the LPG. My LPG died on me today as wel. Once i switchted form petrol to LPG it went dead. Finnaly, when i switched when driving 80 km/hour it was ok and i had no more problems. I got a OMVL with a millenium computer..
Greetings, Rudiger
Thanks Rudiger. And still shame I cannot write in Dutch after so many years...
Indeed, with help from here and also from Croatian Volvo club, maybe I save it, as going to the workshop(s) seems to be not that successful. Have to find really a good place if I want to have LPG...
what's OMVL and millenium computer?? ... you see how much I know about LPG
It works fine again, but I installed separate switch for the 2 LPG electromagnetic valves as I could not detect a problem with the electrical installation in terms of bad fuse or no ground somewhere.
Another LPG "specialist" did not want to take the car for work as they do not have experience with this system, let alone parts, so it was either driving it to the junkyard, or trying this, which I did out of curiosity.
There is a metal box attached to the car below the evaporator, and there was a sticker next to it, unfortunately, everything except the letters LPG is washed out from the sticker. Inside that box there are 2 relays and some electronics. I assume this was responsible to switch the LPG valves on. It has no effect on running the engine - if the ground wire is removed (and it is soldered to the circuit board inside that box, the box itself has no contact with its parts), nothing changes. I am tempted to cut it completely (it has 5-6 wires entering inside).
I'd really like to learn what exactly happens when the system was complete and fuel changed, but there is no detailed scheme on the Internet.
The best I found was this: <a href=" www.expert-gas.ru/index.php?page=61 "> www.expert-gas.ru/index.php?page=61
The vacuum operated valve was already disabled and fixed in one position. There is still occasional high rpm after decceleration: changing to petrol puts the rpm down (and it is never high rpm on petrol), but then again after accelerating engine, it stays high, sometimes going down after 2-3 sec. I cleaned the Idle Control Valve i.e. sprayed WD40 inside, it is not stuck but whether it really works I don't know. Connecting it and disconnecting shows no or very little change to the speed of the engine...maybe idling a bit better on petrol.
Sometimes I have lambda sond light on, then sometimes off after few minutes - should it not stay on once it is lit until disconnecting the battery, regardless of the signals given by the lambda sond? I still think it is something wrong with the computer or its connector. But the car runs perfect on LPG, and starts perfect.
There is also no audible effect if I disconnect the Throttle Position Sensor. But I did not drive without it. It is fairly clean iside the throttle body, I sprayed it also with WD, and the main hose into the intake manifold is not damaged... One original pipe connection, just next to the throttle body, on that main plastic intake pipe is closed. The fuel pressure regulator is also connected to something below the LPG evaporator, into which I think originally a vacuum pipe led out towards an electromagnetic vacuum valve, which was then originally connected to that vacuum operated valve on the LPG hose. But that was already all out of function.... I sprayed all the connections of pipes and hoses and around injectors while engine is running, expecing that if there is a problem, it will affect the work of the engine, or I possibly see an air or vacuum leakage, but nothing could be seen.
I more or less have the same issues, high idle and a lambda lamp that goes on and off.
One of the thing I noticed it that the high idle speed only occurs on LPG, not on petrol. This leaves me to believe the idle valve is not dirty, but it gets a wrong signal.
Strange thing is also when the car is rolling the idle speed is around 2000 rpm. It dropt to 600 rpm when the car completly to a halt (eg infront of a traffic light), so I have the feeling there is a connection between the speed and controlbox towards the idle valve. Btw this issue is only on LPG, not on petrol.
Since I could not find the issue, I went to a friend with lots of knowledge and parts and we decided to block out possible issues. Together we have made the LPG inlet "original" since I have just a LPG mixing ring somewhere in the middle of the inlet hose. Now I have a mixing ring attachted to the airinlet on the engine and a new hose, so I do not have the issue of air leakage.
Next step was the exchange of the air mass meter and the issue was gone. A funny extra was that the electronically controller valve on the vapourator (Actuator) now also suddenly worked and my CO went from 6% to 0.5%.
Hope this helps.
Btw the lambda light still goes on and off, with code 2-1-2. It seems the light is also controlled by speedbumps, so I guess a wire is broken or makes a unplanned connection somewhere. Anyway the car does not run worse if the light goes on.
