No reverse gear in 960
17-03-2009 14:29 #1073240
No reverse gear in 960 is gemaakt door V700 register
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
I Saw this car in Ebay Unfortunately the auction is over, but Does anybody know why this happens, Volvo 960 24V Automatic I noticed the vehicle over the last couple of weeks getting slower to engange reverse. Now will not even attempt. Have had a garage top up fluid. Although has had no effect.
Will Drive forward.
18-03-2009 01:45 #1232345
Beantwoord door V700 register in topic ?
18-03-2009 10:34 #1232352
Beantwoord door V700 register in topic anything
Thanks
You don't have an anwser?
Don't bother then.
Is there someone who has had similar problems?
Here's the car, but the auction is over...
cgi.ebay.nl/ws/eBayISAPI.dll?ViewItem&am...mp;item=220375599820
Don't bother then.
18-03-2009 18:54 #1232379
Beantwoord door V700 register in topic It could
be the (electrical) switch actuated by the gear position lever (that enters the left side of the tranny) which is positioned at the right side close to the exhaust pipe. This switch controls the solenoids that control gear change. The switch forward it settings to the control unit for manual gear box prefix settings or position. It appears that this swicht needs occasional replacement after 10 years or so as contacts wear or age due to high temperature from the exhaust pipe. I recall that this could be the cause, mechanical wear is also an option, though the defect of this switch has been reported before.
Robert
Robert
18-03-2009 21:25 #1232396
Beantwoord door V700 register in topic not to dear
So that would have been a not so expensive repair?
A petty that the car is already sold then.
never mind, there will be other options for sale I reckon..
Thanks for your swift answer.
18-03-2009 21:49 #1232399
Beantwoord door V700 register in topic Pet?
I know you're fond of pets, but to call a brick like this petty, is just a bridge too far, right?Nevertheless, it is a pity, that's true, sold for just over 300 quid with a possibly cheap fix.....Jeroen schreef : A petty that the car is already sold then.
18-03-2009 23:45 #1232420
Beantwoord door V700 register in topic Not entirely
pet⋅ty 1. of little or no importance or consequence: petty grievances. 2. of lesser or secondary importance, merit, etc.; minor: petty considerations. 3. having or showing narrow ideas, interests, etc.: petty minds. 4. mean or ungenerous in small or trifling things: a petty person. 5. showing or caused by meanness of spirit: a petty revenge. 6. of secondary rank, esp. in relation to others of the same class or kind: petty states; a petty tyrant.
Yeah you're right..
But nonetheless. It's petty cash. Well, for someone else it is..
And I need a pat on the back.
Yeah you're right..
